Hello everyone, I'm proud to announce our "other" new toy than our sparkling new HA-171, it's our PT-111 Isolation Transformer.
In case anyone is wondering, yes we are out to drain your Christmas dollars.
Whether it is money that you've saved up to for something else, or money from refunded Christmas gifts. It's all fine with us.
Hehehe, all jokes aside, our PT-111 transformer is built with a very efficient toroidal transformer that can support loads up to 300W without any problems. Input is protected not only with a fuse, an added level of protection is provided by the built-in thermal cutoff switch that automatically cuts the transformer's power input when temperature is abnormally high.
Well, nuff said about the marketingese, here's some photos!
PT-111 front view with the hats off and innards exposed.
PT-111 top view, with the KECES Transformer logo, power control board, and AC outlet in full view. At full load of 300W, the transformer barely gets warm. A transformer of similar performance are often branded and sold as 450W, but we feel loading this transformer up to 300W is the reasonable limit. Load above and beyond 300W may not damage the transformer, but it could adversely affect the sound of your equipment while it is too heavily loaded.
Close up view of the power control board, the small power switch does not actually pass the power to the transformer, it switch on a high current relay to do the job. This board uses regular IEC socket, for those who want to upgrade to IeGO sockets (Gold plated copper or 99.99% pure silver), the custom power control board is being made as of now, and will need around two weeks before it is ready.
Cooper Wiring devices' Hospital Grade IG8300 AC outlet. One of the very best socket that we found that is available at reasonable cost. For the best performance, we made sure the transformer's output is direct enamel wires coming from the core of transformer, reducing the added connection and disruption to the core.
Business end of PT-111, two AC outlet for the equipments that you might have.
Voltage?
This is an
ISOLATION transformer,
not a LINE CONDITIONER
nor Constant Voltage transformer, thus the voltage on the output is directly proportional to the input voltage, except it is fully isolated and a LOT cleaner than what it used to be.
Version suitable for use 100~130V power lines are in stock.
200~260V, step up or step down versions are available upon request, and will take about 7 days before it is ready for shipment.
For customers that requires 200~260V output, please know that we can only supply it with Cooper IG8300 sockets that accepts American type NEMA sockets. If you do not use power cables with NEMA type plugs, you won't be about to plug it into the AC outlets.
Price?
USD $330 plus shipping, custom voltage available at no additional costs. Please understands that custom voltage will require 7 days of lead time before we can ship it out. You may request step up or step down transformer that fits your need exactly.
Shipping charge (PT-111 weights about TWICE what DA-151/131.1/152 weights...):
North America/European/Russian regions: $75USD
Asia/Oceania regions: $50USD (Yes Aussies, Kiwis, that includes you guys.
Central/South America, Africa regions: $100 USD
