0 Members and 1 Guest are viewing this topic. Read 41008 times.
Hey! This is nothing new. I've heard this for sometime now. The fact that Plasma use more electricity is because it need to heat up those cells filled with gas(es) to create plasma. But for LCD you only need to switch on and off the liquid crystal on the screen. I'm not an expert on this and that's all I know. Anyway, it would be interesting to see the actual wattage listed on the back of a Plasma and LCD TV of the same side... give or take a few watts for audio use. Take care,Buddy
PRODUCT ANNUAL COST 20-cu.-ft. refrigerator (a newer top-freezer) $50 25-cu.-ft. refrigerator (a newer side-by-side) 65 32-inch picture-tube 40 36-inch picture-tube 50 37-inch LCD 50 40-inch LCD 55 56-inch rear-projection 65 42-inch plasma, 720p 70 52-inch LCD 80 50-inch plasma, 720p 80 50-inch plasma, 1080p 110
A recent issue of "Real Simple" magazine listed some annual power consumption statistics for a variety of electronics equipment. The ones that interested me were the kW hours and annual cost estimates for each type of TV (plasma, LCD, CRT). The results are summarized below (for TVs smaller than 40"):ITEM Annual Energy Use Annual CostPlasma TV 441 kWH $48.25CRT TV 123 kWH $13.46LCD TV 77 kWH $8.42My question is: why do plasma TVs use more energy than a comparable size LCD? I'm assuming that plasmas are more power-hungry than CRTs because they are "partially on" all the time unless unplugged. But how does an LCD achieve higher efficiency ratings than either?Any insight on this issue would be most appreciated,-dB (a unit measure of noise)P.S. I mention the source of the data because I can't confirm its accuracy or the assumptions that go into their estimates.
That's only 11 cents/kwh. We're paying around 15 cents/kwh.
I'd recommend that everybody get a projector. It's less money per square inch of viewing area. Bob
* Microdisplay rear projector: 0.14 watt per square inch * LCD: 0.29 watt per square inch * Plasma: 0.35 watt per square inch
So projectors are where its at, huh? I admit, I no even less about projectors than I do about conventional (LCD, plasma) flat-screen displays....which is to say, precious little. Where would I start to research these if I wanted to go in that direction?Potential problems for my room: this would be deployed in a basement TV room that is thin (10' +/-), long (25-30') and with low ceilings (just under 7'). Mounting a projector at the back of the room doesn't seem feasible. Mounting it in the ceiling might prove difficult because of the low-ish clearance. Just not sure this would work in this configuration. Any ideas on this?Thanks, -dB
* Microdisplay rear projector: 0.14 watt per square inch* LCD: 0.29 watt per square inch* Plasma: 0.35 watt per square inch
