0 Members and 1 Guest are viewing this topic. Read 760163 times.
Dynamicap-E metalized polypropylene capacitorSome believe these to be among the best metalized polypropylene caps ever made, and I might have to agree with that, if somewhat reluctantly. After all, Mundorf silver/oil and gold/silver are still technically “metalized poly” caps, and they do have a magical something that other poly caps lack, including Dynamicaps. As I have observed before with Vishay poly caps, the Mundorfs have a sense of weight and texture behind the notes, especially in the midrange that keeps music interesting and captivating over longer-term listening. The better poly caps sound balanced, detailed (though not Teflon-detailed), and all the notes are present and accounted for. This is true for Dynamicap as well, and it does one better by being probably the most neutrally balanced among the poly caps. I even dare say it sounds more neutral than something like Mundorf gold/silver or the Russian silver mica’s, so here we have a reasonably affordable capacitor that is quite uncolored, clear, sweet, yet extended. No wonder companies like Alta Vista Audio is using these caps in Counterpoint gear upgrades, not to mention VMPS offering them as upgrades in their speaker crossovers. What about Auricaps? This is a tough one. One’s preferences will have a large part in this choice. Auricaps have a fuller low-midrange to upper-bass presentation compared to Dynamicaps, which makes music richer and more propulsive; they also emulate some of that midrange texturing of Mundorfs. Dynamicaps counter with subjectively more ruler-flat neutrality with less bloom and thickness, sounding cleaner and clearer. I would say consider the way your system sounds now and which direction you want to go before choosing one over the other.
Jon,Have you thought about doing a cheap cap like the Erse pulse? I would love to know how much you are "losing" vs. a standard sonicap or auricap.Also, prior to switching to the EPCOS MKV in my t-amp I was using Vishay 430p on the input caps. I found them a lot more detailed than the auricaps that were in their prior. It might have been a system synergy thing though because I am using single driver Jordans in a small sealed box.
This is a really interesting thread. I just bought some Jensen PIO caps that i am going to use as coupling caps. I would like to have seen them reviewed. Anyone got any thoughts?
I may be testing some Jensen PIO caps soon
Dynamicap-E metalized polypropylene capacitorSome believe these to be among the best metalized polypropylene caps ever made, and I might have to agree with that, if somewhat reluctantly......What about Auricaps? This is a tough one. One’s preferences will have a large part in this choice. Auricaps have a fuller low-midrange to upper-bass presentation compared to Dynamicaps, which makes music richer and more propulsive; they also emulate some of that midrange texturing of Mundorfs. Dynamicaps counter with subjectively more ruler-flat neutrality with less bloom and thickness, sounding cleaner and clearer. I would say consider the way your system sounds now and which direction you want to go before choosing one over the other.
Jon,I understand that this is a very complicated question, but what has been your 'Favorite' capacitor setup (single or bypassed) thus far?I know its subjective, and also varries by application, but in general what would your answer be?Thanks,West
I changed to Multicap RTX and the treble resolution improved and the sound became more alive.
