0 Members and 1 Guest are viewing this topic. Read 23607 times.
Monolith,In reality, the only ICs required for the operation of the ZR amps, as an 'audiophile' amplifier, are those found on page 5 of the pdf schematics. (plus the 7815 and 7915 linear regulators of the low voltage rails, which could be replaced with 317/337[or other] adjustable, and better functioning regulators). By 'audiophile', I mean the minimal requisite circutry needed for operation as a power amplifier. This is by no means a criticism of the CarverPro amps, it is simply an acknowledgement that ...
Monolith, Additionally, IMO, the powerline filter, housed within the IEC receptitcle is there for FCC sec 15 compliance, not for improved sonic quality. It should be replaced with filtering that is less likely to saturate its small inductors and provide both compliance and improved sonics. But that costs money...
So here is a rundown of the mod package: -WBT RCA Inputs -Audience Auric Hook-up wire directly to an IDC connector on the main board, bypassing the input card. This allows you to put the old ribbon cable back in and use the input card at a later date if you so desire. It will also allow you to use any other aftermarket or Carver Pro cards that may be released at a later time with no soldering at all. Simply pull the new IDC connector out. -Papst silent fan. This is the quietest fixed speed fan available in this size. From Germany. -Audience Auric Hook-up wire from the output card to the Binding Posts -WBT Binding Posts
I believe the connection point for Ch1 and Ch2 is under the wind tunnel. I'm trying to verify that. I could not find them visually on the board.
Monolith,I just reread your original post, and realized that you pointed out the possibility of bypassing all of the active circuitry prior to the Tripath chip. Dang! It must have been one of my increasing frequent "senior' moments. That post is amazingly comprehensive. Kudos.
I've done a bit more schematic surfing and think that the direct input points to the Tripath chip, bypassing all those opamps, CH1-INPUT & CH2-INPUT on Page 5 of the schematics, are connected via 'J601' amd 'J602' referenced o ...
You could bolt 4 discrete, TO-2xx package, diodes to a purpose made heatsink, to package a pin-for-pin replacment.
The Papst 612NGL - Constant Velocity Fan ~ 11.2CFM (16db) has proven to be quiet enough. As long as you use rubber washers to stand the fan off from the metal wind tunnel, the fan is virtually inaudible. It can be heard if your ear is closer than a foot from the units front where the fan exhausts, but even at that it is close to silent.Also, if you wire directly to the main board, you will be choosing to use the amp in stereo or mono mode, unless you wire a switch of some kind right after the RCA inpu ...
