0 Members and 1 Guest are viewing this topic. Read 9220 times.
Looks like you have been to the curtain shop lately.
advantage of using two drivers that were similar in sensitivity?
would it matter if you were using 2 amps, a sub amp on the bottom, something nice on top?
Hi Rudolf"I don´t believe in that "linear response on axis" any longer."What approach do you take now?David
I tried the FRS8 on a 4" wide baffle between two vertical 12" dia rolls of carpet which were as close as 1" separation behind the driver. This 'baffle' gave best reproduction for that Visaton; no notable resonances or reflections, and excellent axial reproduction.
