0 Members and 2 Guests are viewing this topic. Read 77741 times.
.... Definitely the woodworking aspects of OB construction are less complex, cheaper and less time consuming than box speakers.Roy
I am also in the process of cloning the CS2's. They are not available in the Netherlands, but I have allready all the drivers, the waveguide and the the DCX 2496. The only thing I am looking for, are the settings of the crossover. I am looking for somebody who can mail me the config file for the DCX 2496.
That depends on the OB, these took me longer than any box speakers I ever built:Of course YMMV
>>You mean like this?>>JeffYES!!!!!What drivers did you use? And are you using the Behringer xover?TIA
I also consider the DCX settings proprietary to Emerald Physics unless Clayton says otherwise. While I appreciate the DIY angle as much as anyone, it simply isn't appropriate to copy them from a legitimately purchased EP DCX and provide them to someone who has not purchased the speakers. I've been asked several times by mail and PM already, and refused to do this
Quote from: TomS on 22 Apr 2008, 11:32 pmI also consider the DCX settings proprietary to Emerald Physics unless Clayton says otherwise. While I appreciate the DIY angle as much as anyone, it simply isn't appropriate to copy them from a legitimately purchased EP DCX and provide them to someone who has not purchased the speakers. I've been asked several times by mail and PM already, and refused to do this Yea, that seems fair. I think Clayton has already disclosed more about the design than most people would. What is most amazing about the CS2s is the quality of their overall presentation using fairly cheap drivers. I think I will take the Dr. Mason approach and instead of cloning the CS2s, just build something better. My apologies to Emerald Physics and Clayton if I was inciting something unethical.
