The RPD-A (Paper Dipole with Amplifier) and Matching Center Channel
0 Members and 1 Guest are viewing this topic. Read 3617 times.
PaulHilgeman
Enjoy!  The RPD-A is the paper version of the Ronin, with the 500W amplifier for the bass driver.  The center channel matches.  Surrounds coming soon!!!
EProvenzano
Sweet :thumb:
Where do you recommend placing the centre channel, above or below the display?  Should it be placed a few feet in front of the display also?
I'm trying to see if I have room to incorporate this.  I might have just enough Claro Walnut left!
Thanks.
PaulHilgeman
This one is intended to be placed above the display.
Because of his equipment set-up it will be around 24" from the rear wall, which is how I tested it and listened to it.
Obviously it is a totally custom design, and should one be needed for below the display, it is certainly possible.
-Paul
