3a Gen. II Specs
0 Members and 1 Guest are viewing this topic. Read 6340 times.
rollypolly
3a Gen. II Specs
« on: 8 Mar 2008, 03:06 pm »
A buddy of mine managed to pick up a mint pair of 3a M3's that included all the original paperwork including the User Manual's and Sales Brochures. I've managed to scan and save them in pdf format. If interested pm me and I'll send you a copy.
From the User Manual here are the specs:
MM:
RMS Power:                      80 watts
Efficiency:                         91(1w/1m)dB
Impedance:                      8 Ohms
Distortion:                        0.4 (NF. 97405) 94dB at 1KHz
Frequency range:              50-25,000hz
Tweeter:                           Soft dome (Vifa D26TG)
Woofer:                            Type - G 126 H
                                        Cone - Carbon
                                        Voice Coil - Alu 17mm
Crossover:                        Bass Midrange - Direct  Couple
                                        Midrange Tweeter - 3 KHz (4.5 +12 dB)
Dimensions HxWxL(cm):  38x25x28/35
Form:                               Monitor
Rec. Amp Power:               30-100w
M1:
RMS Power:                      100 watts
Efficiency:                         92(1w/1m)dB
Impedance:                      8 Ohms
Distortion:                        0.3 (NF. 97405) 94dB at 1KHz
Frequency range:              40-25,000hz
Woofer:                            Type - G 128 H
                                        Cone - Carbon
                                        Voice Coil - Alu 14mm
Dimensions HxWxL(cm):  70x25x32.5
Form:                               Floorstanding
Rec. Amp Power:               30-120w
M2:
Impedance:                      8 Ohms
Tweeter:                           Soft dome (Morel MDT 32)
                                        Cone - Carbon
Dimensions HxWxL(cm):  90x25x15/29
Form:                               Floorstanding
M3:
RMS Power:                      120 watts
Impedance:                      8 Ohms
Frequency range:              30-25,000hz
Midrange:                         1xCone
                                        Cone - Carbon
Crossover:                        Bass Midrange - 500Hz/6db
                                        Midrange Tweeter - 5 KHz /6db
Dimensions HxWxL(cm):  90x28x22/40.5
Form:                               Floorstanding
Rec. Amp Power:               50-150w
M5/MS5:
RMS Power:                      180 watts
Efficiency:                         89(1w/1m)dB
Impedance:                      4 Ohms
Midrange:                         2xCone
Woofer:                            Type - W 120 x2
                                        Cone - Cellulose
                                        Voice Coil - Alu
Crossover:                        Bass Midrange -     120Hz/18db+6db
        600Hz/6dB
                                        Midrange Tweeter - 7 KHz /6db
Dimensions HxWxL(cm):  105x31.5x37
Form:                               Floorstanding
Rec. Amp Power:               50-200w
Cheers!
Rolly
