Ok.... this is appropriately named. The motor is about 12.5" in diameter, 6.5" deep so the motor alone is the size of a Shiva-X.
We are working on trimming some weight because we are up around 100lbs for the motor alone, WITH NEO!
This is looking at the top plate. Nice big 5" Voice Coil provides a pole vent big enough for small animals to climb into. Your going to have to watch the cat because he/she doesn't want to be in there when you fire it up.
Cut-away of the pole, back plate & front plate (not cut-away).
This will represent a high-water mark in the subwoofer market. The Sicko will be within its 1% linear BL range under almost all conditions with the F1200-TS. It will also be well within its suspension linearity and the inductance will be amazingly controlled. In other words, it should be the most linear subwoofer ever made by a long shot.
As you can see from the renderings, the power handling is going to be helped with the open motor design, not to mention the 5" VC so you have voice coil cooling unlike anything on the market.
For you open baffle guys, the motor will be EXTREMELY low-noise. Not only will the motor design be open, the spider landing is going to be equal distance from the top plate as the cone is from the spider landing. This is the kind of driver that will provide THX levels of output at 20Hz on a 3' wide open baffle!
