0 Members and 1 Guest are viewing this topic. Read 44079 times.
Point to point is more compact, cheaper and pretty easy for this project.
Tan - I also like your all in one box with the wall wart inside. Maybe I'll re-do mine to copy that.
i was pondering on Gary's observation that a basic but good linear pws sounds ( with or without Felix) less than the original; cheap SW PWS with the Felix in the AC line..He assumed logically that SW PWS negative effects were "blocked" in a way by the Felix to enter the other audio components.Suppose you do the Felix in the 5V line. It will "block" all the unwanted interference from the Ac line PLUS the unwanted effects from the SW PWS for the SB3 but will not stop those SW effects for the rest of the audio componentsIf now the SW PWS still sound better than the linear PWS, another explanation must be found than Gary's original assumption. If not, the assumption is proven to be fact, no?
Mike,I am doing Felix before and after switching PS (5VC first then 9VDC for Duet) in a few days. Let see what will happen to the sound. Tan
Where does this DC comes from?
Has anyone measured the effects of 0.6 A DC through one of those CMCs???No.............didn't think so.Pat
