0 Members and 2 Guests are viewing this topic. Read 55056 times.
What surprises me is that the measurement distance only seems to show a difference in the general slope of the bass response with the woofer up away from the floor. Can you tell us some general info about the room size and approximate speaker placement for your measurements.
Am I right to conclude that the side panels are triangular with a base of (21+21+baffle thickness) cms and about 80 cm high?
Just a point of clarifications, the actual woofer implementation would be a pair of woofers mounted on your "tapered" H-frame, one firing forward and the other firing towards the rear.
If that the case then you would see the rear of one woofer facing you? The general appearance may not look too good.
