Tweeters in older 3a Generation II models
0 Members and 1 Guest are viewing this topic. Read 8898 times.
rollypolly
« on: 14 Jan 2008, 06:50 pm »
Wondering if anyone here can help me in identifying the tweeters that came with 3a Generation II line of speakers that came out back in 1989 and were made in France.
Just got my hands on a very rare 3a M2 that I'm in the process of updating. Unfortunately, the tweeters aren't original since I don't recall any of 3a's MM, M1, M3, M5 or MS5 models having a soft done tweeter with medal cage over the voice coil. The 3a M2 has the same driver complement as the 3a MM and M1. If anyone knows or can take a peek inside their 3a Gen II speaker I would be much obliged.
Cheers!
Rolly
benson
Re: Tweeters in older 3a Generation II models
« Reply #1 on: 2 Feb 2008, 12:18 pm »
the original tweeters in m2 is a morel mtd 32  :thumb:
benson
« Reply #2 on: 2 Feb 2008, 02:47 pm »
hi rolly
i have teh same model ,i change the binding post for wbt,change the intern wire for dh lab and the capacitor for munrof (silver and oil) and i plug the cable directly to the woofer . the sound is (exquis)
my systeme
shanling cd t-1oo
jasmine set el-156 integre
fim gold sp cable
cardas golden ref
jps lab power cable
rollypolly
« Reply #3 on: 2 Feb 2008, 07:34 pm »
Thanks Benson!!
Wow, so the tweeters that came with my M2's are original. Highly unusual since the rest of the line was using Vifa D26TG tweeters.
Out of curiosity do you recall what the values were for the first-order crossover on the tweeter.
Here's a picture of my speakers that I'm about to update.
Cheers!
Rolly
benson
« Reply #4 on: 4 Feb 2008, 08:55 pm »
hi,yes
is in serie 22mF cap and 10v/16ohm resitor and 4.7mF cap
good chance in your project
bye
ben
