0 Members and 1 Guest are viewing this topic. Read 4270 times.
i've been bugging brian to make a skinnier wersion of the rm40, based upon the 626, since the old harmonic discord daze... he said someting about sending $20k for start-up! hopefully, someting is in the works... i'd like to see at least two midrange ribbons & at least two 6.5" woofers. three would be better! doug s.
How about approximately 50" x 10" x 19" HWD?
Quote from: RibbonSpeakers.netHow about approximately 50" x 10" x 19" HWD? That makes it taller and deeper than the RM40. I think the idea that many have floated over the last couple of years is one with a narrower baffle with height and depth in the RM1/RM2 area. I like the woofer on the side idea; I'd like to have a baffle not much wider than the Neo mid.
I think advantages of such a narrow baffle are minimal to none.
the rm40's are 66" tall. i'd like to see a speaker w/two (or three) 626 woofs, two (or three) neo midrange ribbons, & an fst tweet. no wider than the present 626. i'm not interested in any side-firing woofers. i'd be using these w/subs... doug s.
jim, does brian even make 5.25" drivers? i *know* he has the 6.5" drivers... if he has to tool up for new drivers, forget it! and, he's extolled the wirtues of his 6.5" drivers before... but, if he awreddy has smaller drivers, 5.25" drivers will get ya to 50hz easy - at least the eton drivers, as used in gr-research's diluceos & criterions, do... and, *i* know these are killer drivers. i've heard the criterions, & i have eton's 7" iteration in my meret re's... any of these dri ...
