0 Members and 1 Guest are viewing this topic. Read 4940 times.
The on-board oscillator operates at a nominal frequency of 10kHz. Frequency is increased to 35kHz when pin 1 is connected to V+, allowing the use of smaller external capacitors.
it is supposed to go to V+
Quoteit is supposed to go to V+Holy inversion, Batman! You're absolutely correct. Gads, I can't believe I still make these kinds of mistakes. I even remember checking this out on a scope to make sure all was ok (and then promptly forgot what I did). Instead of dyslexia, I must have polarexia. My entire career has been plagued with inversion errors.Anyway, thanks for catching this! I will update manual. Yes, the trick is to connect pin 1 to pin 8. jh
The TC7662A does not have the ability to boost the internal clock frequency like the 7662B, and the data sheet shows pin 1 as 'NC' (no connection), so I certainly would not connect it to anything (on some IC's [I dunno about this one] 'NC' pins are connected to the device substrate, and it may be a bad thing to connect it to V+).Personally, I can't think of a reason where I'd use the older 7662A.
If you do not build in the recommended stock chassis configuration, you can reduce the potential for high frequency noise contamination by forcing the dc-dc converter to operate at a higher frequency. Connecting pin 1 of U1 to pin 8 does this. Add a jumper on bottom of board (only works with the TC7662BCPA).
