X-Statik and X-Voce at RMAF
0 Members and 1 Guest are viewing this topic. Read 8479 times.
klh
« on: 16 Oct 2007, 06:01 pm »
Did anybody go into this room? How did they sound? How does the X-Voce sound off axis? How do the three front speakers integrate? If you've heard GR-Research's OB-5, how similar/disimilar do they and the X-Statik sound? And, probably more importantly, are they worth the cost difference? Thanks in advance.
Sean Parque
    • http://www.av123.com
Re: X-Statik and X-Voce at RMAF
« Reply #1 on: 23 Oct 2007, 03:18 pm »
I'm guessing you don't want to hear my impression ;)
Sean
jn316
« Reply #2 on: 23 Oct 2007, 05:45 pm »
Check out the AV123 thread here
http://av123forum.com/showthread.php?t=24914
There was quite a bit of discussion about the X-HT room.
For the GR Research info/comparison, others here would have to help you.
klh
« Reply #3 on: 23 Oct 2007, 11:56 pm »
Sean
Nope
Are you crazy? Give me the scoop! Same for the Ninja :).
Sean Parque
« Reply #4 on: 24 Oct 2007, 03:46 pm »
I work for AV123 though... I must be completely and hopelessly biased :)
klh
« Reply #5 on: 24 Oct 2007, 04:45 pm »
I know ;), but it doesn't bother me. You can still state it's strengths and weaknesses... especially compared to the upcoming X-series speakers.
Sean Parque
« Reply #6 on: 25 Oct 2007, 02:49 pm »
Well...
I like the x-statik quite a bit.  It is quite open and transparent.  Very smooth, great off axis response... You can really 'get into' listening to them... I think because they are so open... the sound certainly does not sound like it is coming from the speaker.  The bass is very tight but not hugely plentiful so I will use a sub with them.  The Voce is more of the same as it is built to nearly the same configuration.  The Voce has a little less bass than the Statik's but it is not too big a deal since you will be using a sub anyway for HT.
We have been working very hard at producing products that lead their class.  Sure it sounds like more marketing hyperboyle however take a listen and tell me I'm wrong :)  Maybe you don't like the particular sound, fair enough but tell me it isn't a quaily speaker.  All the coverage from the RMAF has been very positive.  I have read a couple comments about the speakers being a little bright/harsh at the show.  I do think the 2 channel room's integrated amp was not the best match for the speakers but they were also brand new... we actually finished building them in the hotel's hallway the day before the show :)
Sean
