0 Members and 1 Guest are viewing this topic. Read 37162 times.
Robin,you seem to have many tweaks!This one will surprise you, it surprised me.I like it! For me it helped make the speakers disappear and make the soundstage very real.
Not to upstage Jim's stuff as it likely works as intended...but Andrew Marshall of Audio Ideas has sold a product called The Imager for almost 30 years that works similarly. I bought a pair for the same $20.00 that they charge today almost 20 years ago for my (then) bookshelves and was rewarded with better imaging as a result. They're on a version II now I see...http://www.audio-ideas.com/reviews/aig-tweaks.htmlFor $20 or $30 a pair, it's probably a very cost effective tweek in many instances. Except mine today as I have a top-mounted Linaeum tweeter
Quote from: TheChairGuy on 10 Oct 2007, 05:00 amNot to upstage Jim's stuff as it likely works as intended...but Andrew Marshall of Audio Ideas has sold a product called The Imager for almost 30 years that works similarly. I bought a pair for the same $20.00 that they charge today almost 20 years ago for my (then) bookshelves and was rewarded with better imaging as a result. They're on a version II now I see...http://www.audio-ideas.com/reviews/aig-tweaks.htmlFor $20 or $30 a pair, it's probably a very cost effective tweek in many instances. Except mine today as I have a top-mounted Linaeum tweeter I have used these for 18 months on my Loreleis and I like them. Can't beat the price. They blend in fairly well with the tweeter. It's difficult to tell that they are an add-on.
Hi Chairguy,I cannot, I think anyway, use the wool sheeting on my Spendors and use their grill covers. So I ordered three sets of the neoprene rings. One set will be applied to my Spendor S5e and two sets to my Hsu horns in my AV system.I'll report back with my thoughts.Thanks for the tip.
It would be interesting if anyone could A vs. B the neoprene rings for $29 pair versus the felt squares from Jim Goulding for $30.00. The difference is negligible if indeed the felt works better
