0 Members and 1 Guest are viewing this topic. Read 258291 times.
I placed one CBF on the circuit breaker feeding my A/V system. I cannot get to the main wire bundle so I placed one on the main circuit breaker that feeds the whole house and I also placed one in the wall box behind the duplex feeding my system. I wish I could just jump ahead to day 30+. Now the wait begins. Steve
This is great information!!!! I am going to go take a look to see if I can get the panel off. How do I know what the earth ground wire is?
Alan the photo shows the CBF over two breakers. Should not they be horizontal not vertical ? Or am I confused ? charles
what are the best 15A and 20A breakers to replace/install into an existing panel (no plans in our current place to replace or upgrade the entire box, but will probably do that in the future in a different location)?
I think I recall reading somewhere quite a while back a suggestion to replace cheap breakers with better ones (topic indirectly raised again in WillaBe's quote of Alan's recent comments).Can't remember if it was suggested before, but what are the best 15A and 20A breakers to replace/install into an existing panel (no plans in our current place to replace or upgrade the entire box, but will probably do that in the future in a different location)?
Alan's Blog mentions that he can no longer answer question on this forum. Maybe because he's getting too much attention and he's not a sponsor. Anyway, check out his new facebook page if you are interested.
