0 Members and 1 Guest are viewing this topic. Read 3399 times.
Is there some discoloration of the back half of the right heat sink fins? When you photographed it from the front is shows up in the top of the R side heat sinks and then when you photographed it from the rear it became the lower L side ... so, the same set of heat sinks fins. Doesn't appear to be the camera or lighting.Regards,Lou
