0 Members and 1 Guest are viewing this topic. Read 23885 times.
Isn't the "proximity effect" a characteristic of directional microphones only? I don't think omni condenser mics have a proximity effect.
Quote from: Rick Craig on 10 Sep 2007, 04:18 pmThere's also something called proximity effect where the low frequencies can be exaggerated by certain types of microphones. I think something similar happens when measuring an array and have observed a low frequency tilt that can vary depending on the measurement distance.Proximity effect AFAIK, exists in all mics. Condenser mics are much less prone to it than dynamic mics. (I believe calibration and testing mics are all condenser type) It tilts up bass response when placed in near proximity, and rolls off bass with distance. I'm not sure how that would make for getting a real reading 1/4" away from a driver. It would seem that proximity effect would skew the results, no?When we mic bass drums for example, we have often have to mic from a distance in order to get proper bass and fundemental pitch, along with tone/overtones. The theory being that the low waveforms are so long that they are missed entirely by close miking. I'm not sure on the theory, but in application, close miking never yields realistic bass response on instruments.Cheers
The next question I have is that I seems to notice that most line arrays are built with small drivers (less than 8"), so aren't these drivers limited by their inherent limitation to produce frequency below say 50Hz??
The bottom line is that the bass extension is not going to be any different whether you have one woofer (like a compact 2-way) or several woofers in an array.
The only accurate way to measure the true low frequency extension of a system is to do a near field test where you place the microphone a 1/4" from the woofer (sealed box system) or take a sum of the woofer's output and the port's output in a ported design.
The array will move more air (increased cone area = more displacement); however, it you want true low octave extension you'll need a subwoofer to do that. Without active equalization the best you can expect from a ported 7" driver is a -3db point of 40-45hz. Some drivers I've seen (and measured) in other commercial arrays won't even go that low.
I guess the rules of physics are different in Texas
So who do you believe - Danny or Don Keele?
Meaning that a mic placed higher up or something will not place an image higher up in play back. No speaker will change this either.
I easily hear effects come directly from spots high up on the ceiling verses effects way down low in the sound stage. Q sound recordings are especially good about this effect.
Typically down low images are forward and up front while higher up sounds are deeper and further back in the sound stage.
If you unplug one speaker you will quickly note that the image height is limited to the speaker and driver placement. It will not extend above or below the speaker in any way. Just give it a shot and you'll see.
Now a line source will not in any way diminish this effect in fact the varying degrees of height in image is typically better with the line sources than point sources.
If you have a line that's not long enough to support the nearfield effect of the 20-40hz octave (which all of your designs qualify for) then the in-room response of the lower octave should actually be reduced not increased in your measurements.
One of the main reasons line arrays are used in home and pro audio is that they interface better with the room.
The image effect from ceiling and floor (their reflections from those surfaces acts like additional drivers) makes the array act as if it is much longer.
If you have to apply passive "bass management" then you obviously have a box that's tuned wrong
and / or a problem with your crossover design.
A good design will work well in a variety of size rooms regardless of the room gain because the low frequencies are evenly distributed in the nearfield.
...Talking about the benefits of LAs is fine, but to do so without addressing the issue of time smear and its effect on imaging smells of promotion...
QuoteSo who do you believe - Danny or Don Keele? Both! I'd think that a line array measured at 1/4 inch will have the same problem as measuring a large woofer to higher frequencies in the nearfield (which Keele will tell you doesn't work so well). Since the long dimension of the array is a lot larger than the diameter of the single woofer, the "high frequencies" for the array where this starts to happen would be lower than they are for the woofer, getting down to the tens of Hz. Or wouldn' it?Also, a line array that goes essentially floor to ceiling should have a nearfield effect (at listening position) to even very low frequencies. The image effect from ceiling and floor (their reflections from those surfaces acts like additional drivers) makes the array act as if it is much longer.
Fred,Line array discussions are always entertaining, because it separates the men from the boys in terms of who actually knows what they are talking about vs those who think they do, and the "who's is bigger" stuff below the surface is a riot. I do, however, think the sales pitches are a bit over the top, since there are circles for that. Talking about the benefits of LAs is fine, but to do so without addressing the issue of time smear and its effect on imaging smells of promotion by at least 3 parties in this thread so far. FWIW, measuring array behavior in the very near field is plain silly.
After reading your post I measured the woofer array. The enclosure is 6' 2" tall, but that's deceiving. With the eight closely spaced 7" woofers, it's only 4' 5" from the center of the bottom woofer to the center of the top woofer. I listen from about 12' out from the baffles, so the distances to the respecitve drivers doesn't vary too much. The tweeter array doesn't matter because with the ribbons' vertical directionality the only one I'm hearing is the one that's at ear height.
3. The nature of how sound disperses from a line array leads to better in-room behavior. Not only is floor and ceiling bounce virtually eliminated, but that also eliminates the floor/ceiling room mode from having an influence.
The nearfield coupling of course depends on the length of the line but even if you have a 7 ft. line it only extends the nearfield down to about 160hz.
A simple side wall reflection can be many times greater with delay of 4 to 6 mili-seconds. How much does this smear the sound? Some say it needs to be at least 8 mili-seconds of a delay to even hear it as a delay. Some say a little less. Whatever it is it really doesn't matter for this example.
