0 Members and 1 Guest are viewing this topic. Read 6836 times.
Also, Is it correct to set up each sub independantly? I'm guessing you set one up and calibrate it and then calibrate the second one w/out turning the other one on? Or should both be left on when calibrating? Confused
Thanks for the feedback guys! Oris98 I was wondering if you are using filters or anything like that. Is your cross over set to 80hz for a reason? Another major plus is the 30 in-home period. I can go to a lot of dealers to see a bunch of different subs but until they are in my place I won't know how they sound...
...My speakers are rated -3db at 55Hz ...I ended up setting the Titan at its lowest crossover point...
I guess it must be like Mike said, all about the mains/room interaction. Makes me want to revisit my own Force XL settings now!
Awesome! I know they will sound even better as I get them dialed in. I have one quick question about the phase. Since I have the subs positioned on the same wall slightly behind the speakers should the phase be set to 0 or not necessarily? Thanks!
