0 Members and 1 Guest are viewing this topic. Read 4355 times.
I was listening to a song, from a group called 2nd Chapter Of Acts.
QuoteI was listening to a song, from a group called 2nd Chapter Of Acts.Wow! That's blast from the past. I haven't heard them in years. I had a few of their records back in the late '70s, early '80s. Are they still making records?BTW, nice IC review. Very helpful descriptions.Russ
I'll have to hunt down the CD. Would also like to find the Narnia album. That was very well done and really complemented the spirit of the story.
I only just read this review by Ray as he posted a small 'correction' to it elsewhere. I found what you found...using magnet wire speaker cables (which I think is the anti-cable configuration) versus various brands of 'stranded' cables. The wholeness and dynamics were excellent - somehow solid core hunks of copper cable and minimal dialectric interaction seems to enhance these virtues - at the expense of one-note and bass tightness (I think the esteemable Carlman referred to solid care bass long ago as 'bladdy, bladdy' bass) and micro-level details. In the end, it's disadvantages were too many for me.Ray, you might want to try the Alpha-Core IC's. Even their silver series is not hideously expensive, but they give you that wholeness and dynamics of the magnet wire stuff...but with less of the 'bladdy' bass. Use only short lengths - as it has the lowest levels of inductance in the business, it has exceptionally high levels of capacitance. In the end, the Alpha-Core IC's didn't quite make the grade for me - but they were damn close to perfect in several areas that may be more important to you. As it's only you that needs to be impressed, it doesn't matter what failings I found with them They, that is the Goertz design, actually seems to work far better as a speaker cable (their copper series is not terribly expensive in short-ish lengths) as the remarkably low inductance is most appreciated, while the very, very high level of capacitance is of minimal concern for most modern amplifiers. As well, they terminate their speaker cables in zoebel networks so that your amps will remain stable (that is , not oscillate) is use. I pair them with a 50 year old set of tube monoblocks that would otherwise, almost surely, oscillate if the zoebels were not employed. They oscillated badly and at low levels with similarly high capacitance Kimber 4TC's in use.Again, as ultra-high capacitance is a concern for any amp to some extent, keeping length minimal is a good practice even on speaker cables. Mine are only 5' pairs, for instance.I've tried a bunch of speaker cables (sorry for diverging off-topic, Ray ), but the Alpha-Core MI2 is the only one I've ever used that sounded like a definitive upgrade with any upstream components in tandem with it. The others used were mostly 'sideways' moves up or down the sonic ladder.Good review, thanks John / TCGHi Chair Guy,Thanks for the heads up. I'd be using a meter pair for the IC's Is that ok?So what did you end up with for IC's?Got some idea of prices?Ray
