Thanks for the responses, Bob & James. So, if I understand your responses correctly, the following statements are true:
1. My 4B SST and 9B SST are not fully internally balanced
2. The 4B SST and 9B SST (along with all Bryston amps) have fully balanced differential inputs.
If both of these statements are true, is it fair for me to assume that by using balanced cables as opposed to RCA composite interconnects, I will achieve less noise? Will this be noticeable? Does it equate to a higher signal-to-noise ratio?
I'm trying to decide if it's worth using balanced cables in my setup...hence, all of these questions. If the difference is inaudible, I won't bother, but if there's a chance at a performnance improvement, I'm all over it. If it matters, my pre/pro right now is a Lexicon MC-12B.
Scott
