We have a limited number of values available in our MWI Capacitor line and are now offering them for DIY or OEM use.
Our Best capacitor is our MWI TEF series of Teflon film and foil capacitors. We have the following values available:
.01uf-400V (.875"L x .5"Dia.)
.1uf-400V (1.125"L x 1.25"Dia.)
.22uf-400V (1.5"L x 1.25"Dia.)
These are THE BEST capacitors that we know of for use in signal coupling and bypass as well as power supply bypass. Please note dimensions as the TEF series of capacitors are very large physically. For instance, the .1uf-400V TEF cap is nearly as large as the 4.7uf-400V MOIP type MWI capacitors.
Our best larger value capacitors for signal coupling and power supplies are a metalized oil-impregnated polypropylene. Our oil-impregnated series in place of other capacitors will increase overall body and weight of the music, without sacrificing any detail, dynamics or resolution. Other PIO - paper in oil and other metalized oil-impregnated caps that I have heard will add warmth and body, but at the expense of detail. Our capacitors were specifically designed to offer both body/weight and detail/resolution.
The following values are available:
.1uf-400V (.75"L x .625" Dia.)
1uf-400V (1.125"L x .875"Dia.)
4.7uf-400V (1.375"L x 1.5"Dia.)
Above pricing for all caps is in quantities < 10 pieces. Please call for pricing in quantities > 10 of any value.
Manufacturers please call for OEM quantity pricing.
[All values are +/-10% - matching available for add'l charge]
Thanks and I look forward to hearing from you.
Dan Wright
President, ModWright Instruments Inc.
