Custom Rectangle sizes now available!
0 Members and 1 Guest are viewing this topic. Read 4441 times.
8thnerve
« on: 9 May 2007, 04:00 pm »
I am happy to announce that we are now taking orders for custom sized Rectangles!  If you weren't able to squeeze another full size Rectangle into your space, now you can order exactly the right size to completely eliminate your corner distortion.
Contact me for details.
Best Regards,
Nathan Loyer
Eighth Nerve
brj
Re: Custom Rectangle sizes now available!
« Reply #1 on: 9 May 2007, 05:08 pm »
Nice development, Nathan!
Any maximum or minimum length?
Beyond a given length, I'm guessing you would need some sort of additional supports mid-span.
8thnerve
« Reply #2 on: 14 May 2007, 06:37 pm »
I don't have any maxes or minimums specified, but at some large length it would begin to sag, and longer ones will be more expensive.  I'd recommend using the standard size, and adding a shorter one to complete the distance.  Contact me for more information on how to best address your space.
