0 Members and 1 Guest are viewing this topic. Read 15205 times.
Are there other subwoofers made that are suitable, if not flat out designed, for OB??
I have no measuring gear, but have done sweeps at high volume with my Mach5 12's, and can report not hearing any chuffing or slapping etc, at deep excursion levels.I think this one, for me, wins the bang for the buck award - http://www.mach5audio.com/product_info.php?cPath=48&products_id=53&osCsid=393aade90eec23873a79281352c163be USD - $70 plus shippingCast basket, rubber surround, FS - 26HzXMAX - 13mm one wayQTS with one VC left open - 0.64
tubamark,I think Mark is right on this. Here is a very illustrative exemplary spec: http://www.visaton.de/en/chassis_zubehoer/tiefton/gf200_2x4.html/Erling
A driver doesn't need to be designed especially for infinite baffle or dipole operation.Smooth frequency responseLow distortionLow noiseare what you are looking for.If Q is too low you use a simple series resistor to adjust it or active parametric E.Q.This driver is one of the best available and at $160.00 is too cheap to pass up.http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=295-468It has three faraday rings and a huge motor giving it very low distortion.It's displacement is 2.4 litersGood looking too.Metal cone with it's first breakup mode at 1.6khz.
