0 Members and 1 Guest are viewing this topic. Read 118229 times.
In addition to the many great suggestions, I'd like to also recommend room air filtration and humidifiers... build me a dust cover that covers my entire turntable, keeping the contaminates away from the platter mat and linear tracking arm tube, etc. Seperate cleaning brushes for cleaning and rinsing also recommended and I'd also suggest keeping them in a Tupperwear container..
(1) Not trying to start anything, but why not keep your clean record brushes in a sealed container? Away from environmental nasties?(2) And I'd have to agree 100% with your dust cover comment. I can't imagine anyone using one while playing an LP.
I use my shop-vac.....
I have had a local granite company make me a base for my turntable for about 100 bucks. I have put Audio Technica footers under the granite and then the turntable on top. Granite stops noise like nothing else can. Vibrations can be felt on the stand and they die on the granite!I also like:Shure SFG-2 stylus force guageDiscwasher D4 record brush (I found a new one in a lady's attic!)Milty Zero-stat gun.I also wet brush the record before I play a side with the D4 brush and a spray of home made solution 3/4 distilled water and 1/4 99% isopropyl Alcohol in a small mist spray bottle.
This is a tonearm lifter for $45:http://www.partsconnexion.com/accessories_analog_qup.html?utm_source=getresponse&utm_medium=email&utm_campaign=1express&utm_content=pcX%E2%80%99s+BULK+BUY+BLOW-OUT%3A+40%25+to+50%25+Off+BUY+BACK+Capacitor+Specials+%2B+45%25+Off+BAT+VK-3i+Preamp+%26+VK-200+Amp%3B+25%25+Off+MUSIC-HALL+5.1SE+Turntable%3B+30%25+Off+BURSON+Soloist+Headphone+Amp
Another lift option:http://www.expressimoaudio.com/lift.htmlI'm going to try this one eventually. Unfortunately, the Q-up didn't work with my Townshend Rock 7 due to its "Naked" design (no plinth to speak of). Maybe I can rig something that works with the Expressimo.
