0 Members and 1 Guest are viewing this topic. Read 117778 times.
I will get rid of some myths for you all 1. Stylus cleaningYou will never need a stylus cleaning tool in your life if you keep your records clean, dustcover on the turntable when not in use, and use a mat which is not prone to creating static electricity. I keep my Vinyl scroupulously clean, but I find a great deal of my used Vinyl will once properly cleaned go through a burnishing and knockin out the rocks for the 1st or second post wet clean plays, some of ther crudwill foul a stylus, if afordability is the issue a small peice of Magic Eraserand or a small section of the Linn Recommended Green sandpaper willcost essentaily nothing and do a very worthwhile job.A Zen Dust used every side will dramatically extend styli service lifeeven with clean vinyl.2. Record Cleaning Machines...... are incredibly essential for vinyl listening. If you are going to be listening to vinyl more than any other source option, it is the numero uno tool. I have been through the ins and outs of vinyl cleanline ...
You pour the consentrate intoa gallon of distilled water. Then pour back into the spray bottle. I use about 8 to 10 sprays per side.
does one really need a digital force gauge,or are the beams good enough ???? where is a good place to buy a dig gauge ???? thks
K Works IsoFeet under the TT have to heard to be believed. Takes a VPI Scout into Scoutmaster territory. Contact igor at: gorcuz@yahoo.com
