0 Members and 2 Guests are viewing this topic. Read 90353 times.
However as soon as I arrived home and connected the Swift yesterday I put on the Copeland cd we were listening to at your place. The improvement in the bass was quite striking; it had become much more prominent and was now in balance with the midrange and high frequencies, an unexpected bonus.Cheers,Neil
Individually, each improvement is subtle, but the overall improvement is well worth the money and effort IMHO. For a few hundred dollars it takes the GK-1 up another notch. I haven't heard any A$10k+ pre-amps but my GK-1 easily matches all pre-amps I've heard up to A$7500. Though I wouldn't go so far as to describe the scale of improvement as being equal to a major component upgrade, I think it would be fair to say that it was equal to a minor component upgrade.... and for anyone eager to glean every last iota of performance from their system, that's not bad for a few hundred bucks!It had already been modded with TKD 2P65S stepped attenuator (http://www.thlaudio.com/indexE.htm) & Vishay S102 bypass resistors, Vampire OFC RCA's, twin grounded shielding plates, Dynamat Extreme damping material on chassis, damped PCB mounts, NOS Siemens gold pin 7308 tubes, no source switch in signal path, etc.
Hi Neil,When you say "The improvement in the bass was quite striking; it had become much more prominent ...", are you talking about:* an increase in the level of bass compared to the rest of the frequencies (IMO that's what you appear to be saying?)* bass was extended lower, or* it was crisper bass?Regards,Andy
I can "copy" the component layout of the GK-1 pcb on a flat spruce board of 3mm thickness, bore holes according to the topology draw the paths on the wood at the underside and do point to point wiring with thin single gold (24 krt) wire insulated in oily "virgin" paper and then varnish the underside with C39 hmm.
ah haaaa !!Teflon IS better than the usual pcb plactics or fiber glass, but, butt, butte Andy,is teflon's resonance property hearing wise SWEEEET? Does it add this tube like life like warmish support to the sound like wood is always doing?I mean how would a teflon Cello sound? A piano cabinet of Teflon? Because i can never damp to zero the vibrations of the amp ( enclosure and pcb/s) I will have to accept those vibrations. But the carrier or medium of those vibrations is in this case the PCB. So this carrier will add its "tone" to those vibrations. And from wood (spruce, maple) it is proven this "tone" supports the music maybe the best way unwanted vibs can do. Some expensive carbon composites may work also)
*.....which dramatically improves the sound of the LP12 ... so CF-composites can indeed do good! However, the improvement from the CF-composite subchassis IMO is not due to any "beautiful tone" it has ... but rather, simply that because it is stiff and light, it doesn't have any of the vibration problems which are inherent in the pressed-steel subchassis. So it's simply hard physics, not wishy-washy greeny thinking! Regards,Andy
Maybe ,Andy man You could make a rigid light aluminum frame for the LP12 or from a special rigid and light plastic ( from a mall) and i can guarantee you the carbon based will sound better. That is why aluminum or titanium Cello's will NOT sound musical pleasing,
ah it is all in the ears...
