Just to say hello...
0 Members and 1 Guest are viewing this topic. Read 6168 times.
thomaspf
« on: 23 Jul 2003, 05:05 am »
I just wanted to drop in and say hi!
Maybe James could add a link somewhere on the Bryston site that points to this forum. I only learned about it on avsforum.
Cheers
    Thomas
jethro
Re: Just to say hello...
« Reply #1 on: 23 Jul 2003, 05:59 pm »
Quote from: thomaspf
Cheers
    Thomas
Sounds like a good idea. If you are thinking about doing this James, you should probably check with "theborg" (site admin) just to make sure it is OK. If the Bryston link happens, perhaps you (James) can approach PMC as well ?
Now that the circle actually exists, I plan to post an announcement to some of the other discussion sites that I frequent.
theborg
« Reply #2 on: 24 Jul 2003, 07:00 am »
It's more than OK :)
