AudioCircle Logo - RightAudioCircle Logo - Left
Pages: [1]   Go Down
Author Topic: FRYBABY and XLR Cables  (Read 4636 times)
0 Members and 1 Guest are viewing this topic.
hagtech
« on: 12 Mar 2007, 10:31 PM »
After some thought, a customer helped me realize that a FRYBABY could indeed break-in a balanced XLR cable.  Or more specifically, a string of them.  It's just not easy.  And it takes extra alligator clip wires and paperclips (or some other pin to contact the female side).  The trick is to split it into steps.  You do the signal pair first, then the shield/return.  Follow these steps:
1)  Connect one FRYBABY output to pin 2 of cable.  Connect other output to pin 3.  This is "voltage" mode burn.
2)  Short pins 2 and 3 at far end.  This is "current" mode burn.
3)  Combine pins 2 and 3 into one FRYBABY output.  Use other output for pin 1.
4)  Add jumpers at far end to short pin 2 and 3 to pin 1.
That should do it!
jh
Bassman59
  • Registered
Re: FRYBABY and XLR Cables
« Reply #1 on: 18 Feb 2008, 11:49 PM »
Oh My God.
This is some weapons-grade bullshit.
Sticks and Monitors
  • Registered
« Reply #2 on: 19 Feb 2008, 06:31 PM »
How do you properly break-in the alligator clips and the paper clips prior to use?
Is there a recommended burn-in time?
Pages: [1]   Go Up
« previous next »
Page created in 0.083 seconds with 27 queries.
