0 Members and 1 Guest are viewing this topic. Read 10054 times.
Buddy,Here is part of an email I recently sent to Richard at Signature Sound after his recommendation of the Benz Micro Ace LO.......female vocals were seductive, ...Ron
Hi SET man,Sorry to hear re your cartridge. Anyway that's a good reason for you to change to a Benz Ace. To add on to what the others said about the Benz. I already used two Benz. ...Benz are way better in terms of musical presentation and vocal sweetness...
Hey!Well, there have lots of talk about cart like Grado and Dynavector here. But I'm wondering how these Swiss made Benz-Micro carts compare to others. So, any happy Benz-Micro user out there? Or anyone that have used this brand... even better this model? Any experience and comment?Take care,Buddy
I just bought the ACE High Output version and it should be here on Saturday or Monday So far I have two person say good things about this family of cart and especially good midrange. And personally I put a high value on midrange... if you can't get the mid right than nothing else matter. Maybe that's why I have SET amps + Single Driver Speaker.... BTW... it would be great to see how much other load this cart on their phono pre... of cause the High Output version will need to be load higher at 1000ohm+
I'd like to know from the Benz owners if they use the Lo, medium or High output version, and what one might expect the differences to be between them provided one owns a phono preamp that can accommodate them all?
Yeah, I for one, would love to see that head-to-head of two good combatants, Buddy
