what drivers are used?
I had a custom Neo 8 built by BG Corp.
See info here:
http://www.audiocircle.com/index.php?topic=21017.0I also designed a new woofer just for this application. It is the new M-165LS.
You can read info about it here:
http://www.audiocircle.com/index.php?topic=21141.40what is the x-over topology?
Proprietary of coarse.
Drivers are acoustically in phase out to 40 degrees off axis in either direction with no phase cancellation. It features or bass management system to.
what is the efficiency & load?
I am going to conservatively rate them as 90db 1 watt/1 meter. Keep in mind that a line source only looses 3db per doubling of distance, unlike a point source that looses 6db per doubling of distance. So at 4 meters away the output is equivalent to a point that is rated at 96db sensitivity.
Here is the impedance response. with varying amounts of bass management.
The bass management system allows the user to vary the output in the 40Hz to 100Hz range to mirror image their room gain. The different curves shown represent the effect of different resistor levels used in the bass management system.
I will conservatively rate it at a -3db down point in the mid 20's, but in my room it was flat to 20Hz, and in Art's room the -3db down point was in the upper teens.
same questions for the ls-9...
It will be similar.
Danny, did you make any changes from the prototype that was at Arts house? Or will the kit be the same as those?
The kit is exactly as the prototype pair heard at Art's.
