0 Members and 1 Guest are viewing this topic. Read 4300 times.
How many different types of devises are there in this category?We have isolation devises that do.......We have filtration devises that do........We have balanced power devises that do.......We have surge suppressors that do......any more?
That's what I about figured, DVV. I have heard nothing good about surge supression other than saving components from spikes and bolts. I get miffed on post talking about filtration and issolation. What is the difference? Are they inclusive? Sometimes? I guess I need to read some web sites. Better yet, how long is the waiting list for the Dezorel?
A friend of mine just gave me an iso trans that they were throwing out at his work. It's an IBM device that was designed to be a clean source of power for test equipment in computer rooms. He figures it's from the early '80's. This thing looks like it's never been used. It's a 240v-120v rated 5A@240 and 9A@120v. That should make it just over 1KvA on the 120v side. I was thinking of using it for my amp which I believe has 2 500vA trans. in it. Will this be cutting it too close in terms of the 1KvA power available?
I'd be inclined to try it and see how it sounds. The rating seems fine. I'm a bit puzzled by the 240V though. This is the primary voltage? Is it intended to be connected across both phases of the mains?
