0 Members and 1 Guest are viewing this topic. Read 1983 times.
I am in the midst of auditioning the Sapphire XLs. I am using a sub and the line-level filters on the mains. I've experimented with both inserting and removing the foam port stuffers. I was finding that the use of the stuffers was affecting not only the strength of the bass, but also had an effect on midrange tonality - which to me is the most important thing I look for. I want just the right amount of warmth in female voices and brass instruments, without sounding bloomy. Alas, I felt that without the stuffer, the sound was a bit too warm, and with the stuffer it was a bit too harsh.In search of the Goldilocks solution, I naturally decided to experiment with inserting the stuffers part of the way but not all of the way in to the ports. To my amazement, I found that by making very small changes in the amount of insertion, I was able to precisely fine-tune the midrange warmth to the EXACT amount I desired. This was exciting not only because it let me get exactly the sound I was looking for, but also because it was tweak nirvana! Combining this with the precise imaging, huge stoundstage, smooth response and detailed refinement that are obvious hallmarks of the Sapphire XLs have made them for me the perfect speaker.I'd encourage other owners to experiment with this, and, Mike, you might want to mention this option in the next version of the support materials.
Mike, the kudos are all yours, for your great product and support. It should be obvious that a whole host of variables - room conditions, cables, power conditioning -have non-trivial effects on the sound, and a mechanism to make small tweaks to adjust for these from system to sytem is the ideal way to provide the greatest assurance of things being exactly right in YOUR system. I never expected this could be achieved in so simple a manner however.
