Hi All,
Here is the info I have so far.
HiDef compressed format has too much bandwidth to be sent vis S/PDIF from a DVD player to a receiver. Thus the new HiDef formats must send across the 4 I2S lines as per the HDMI spec version 1.3. HDMI 1.2 chips cannot receive compressed HiDef bit streams, only HDMI 1.3 chips are able to.
HDMI 1.3 requires new HDMI receiver chips as the data rate is much higher than HDMI 1.2. I should add that HDMI 1.3 receiver chips are now available as samples only.
We get the decoders and the basic system from TI. As such we cannot do anything with the HiDef decoders until TI releases them as part of the Performance Audio system. TI does not expect a formal release with the HiDef decoders until the end of Q1, 2007.
It will probably take us 3 months to integrate this release with our code. It is a significant release with lots of changes. The 3 months is just my guess. I am sure the engineers would be more pessimistic based on the number of changes expected and the fact that the release will probably have various problems and not be backwards compatible. TI told me that they did not expect most customers to have HiDef decoder systems available until the CEDIA (September 07) time frame.
For more info on HDMI, see HDMI site:
http://www.hdmi.org/ Under Press, FAQ, Learning Center and Manufacturer/Specification.
There is a pretty good all inclusive article in Wikipedia:
http://en.wikipedia.org/wiki/High-Definition_Multimedia_Interface james
