Tyrro:
Brand new, never used. $65 for both. - SOLD
EXPRESSIMO AUDIO REGA VTA ADJUSTER FOR RB250, 300 & 600 --------------------------------------------------------------------
Expressimo Audio has ceased to make most of their quality accessories! We have bought out the rest of their inventory and have a limited supply of these items left! Order before they are gone forever!
Machined from Aircraft Aluminum Expressimo's VTA for Rega 250-300-600 is the only thin wall, low profile, full threaded, screw on, calibrated VTA adjuster sleeve with scale available! Don't be fooled by imitations, this adjuster has the thinnest screw-on adjuster with scale out there. Simply drop-in the VTA, no screws or drilling, installs in minutes! DOES NOT WORK WITH REGA RB900 ARM!
Specifications: Outside diameter - 15/16" Minimum height - 1/32" Maximum height - 3/8"
EXPRESSIMO AUDIO REGA LOWER TONEARM LOCKING NUT UPGRADE KIT ------------------------------------------------------------------------
For all Rega Type RB250, RB300 & RB600 tonearms with threaded armpost.
Lower tonearm locking nut kit, includes two stainless steel washers. A must when there is not enough thread for the stock Rega Nut after optimizing your VTA.
Replace your stock Rega Lower Locking Nut with the Expressimo Stainless Steel Locking Nut Upgrade for improved performance. This kit not only gives increased rigidity and dampening but also allows you to adjust your VTA even higher (if needed for optimum VTA adjustment) when using the Expressimo VTA Adjuster.
