0 Members and 1 Guest are viewing this topic. Read 17001 times.
QuoteI think you're right about break in. The Modwright has improved a lot since I first got it. I probably have about 50 hours on it now.It won't come into its own until 300 hours. 500 if it has Blackgate caps. Just keep it on 24/7.
Too bad you didn't have the opportunity to try the Modwright with the Odyssey Monos, with everything else the same. I'd think this would have been a killer combo, yet many people love the Modwright/D200 combo, too.Was the SWL9.0SE purchased used or new?Hang in there and see what Dusty has to say. If the D200s have a problem, he'll make it right.
Connect one decent cd player like the rega planet or jupiter to your pre-amp with a good interconnect and see how it sounds. Squeezebox ! jeez !
Quote from: hertz on 18 Jul 2006, 02:05 pmConnect one decent cd player like the rega planet or jupiter to your pre-amp with a good interconnect and see how it sounds. Squeezebox ! jeez !The Planet or Jupiter is not anywhere close to the quality of a modified squeezebox!I would put my Bolder Cable modified SB2 + Bolder Cable Ultimate PS against almost ANY digital front end out there based on my experience and some direct comparisons.George
Please disregard everything I have said about the D-200's so far. . I have been using Slimserver firmware 15 for my Squeezebox. I switched to firmware 48 and volume levels are normal again. I am able to blow my eardrums out now! I switched the firmware back to version 15, and I still have high volume levels.I think what happened is that I used the preamp attenuation feature on Slimserver when I was running the Squeezebox straight to my my B&K while I was waiting to receive the Modwright. I turned it off when I received the Modwright, but I don't think it took affect for some reason. Now the music is loud when the volume on the Modwright is around 12:00.Now I seem to have more bass and fullness. I am not ready to evaluate the D-200's yet, but things sound better.
