RAVA with Electrostats
0 Members and 2 Guests are viewing this topic. Read 4007 times.
amandarae
« on: 22 May 2003, 04:33 am »
Hello,
Does anybody heard the RAVA'S (SE or not) paired with electrostats?
I am leaning on buying two units for stereo listening only.   My speakers are Martin Logans (35Hz-20kHz, Xover at 250 Hz.) with Stratos Monos and ARC LS-12 preamp.  Room is 14 x 18 x 8.  Martin Logan woofers are sealed, that is why I am really considering the Rava's.
Your response/comments are highly appreciated.
Best regards :)
« Reply #1 on: 22 May 2003, 10:48 am »
How do you plan to crossover?
If you run your stats full range and bring the sub under them then you will want to do a frequency sweep to see if the internal crossovers are low enough.  Rava=40Hz (I think) and the SE =50Hz.
If you use an external xover then you should have no problem.
amandarae
« Reply #2 on: 22 May 2003, 07:19 pm »
Thanks MaxCast!
JoshK
« Reply #3 on: 22 May 2003, 07:33 pm »
I run a standard Rava with a pair of MGMC1's in my HT with very good results!
