Honda Accord iPod integration. iPod tunes in your car stereo. DIY install
0 Members and 1 Guest are viewing this topic. Read 1918 times.
Levi
Read on...I included installation.
I recently acquired a 2003 Honda Accord Ex and don't know if I can integrate my iPod into my stereo.  It has the integrated climate control/stereo/6cd changer.
Has anyone have a third party device?  I was told that the DLO Transdock $99 works but not really sure.
I do not like iTrip or the idea of broadcasting music through the FM.
Thanks guys.
« Last Edit: 23 Aug 2006, 03:33 pm by Levi »
Papajin
Playing iPod tunes in your car stereo
« Reply #1 on: 18 Mar 2006, 05:03 pm »
I've been watching for the Neo iOn for my car.  There seems to be one available for your Honda though.
Folsom
« Reply #2 on: 18 Mar 2006, 05:46 pm »
I would look at the Neo... Well I would look at any thing with out freaking FM modulation.
If your six disc uses RCA's perhaps you could route them to a docking station as well. Either way the FM modulation is still FM..... While it it seems to sound at first you can tell that the music is a little flat.
Levi
« Reply #3 on: 18 Mar 2006, 06:38 pm »
Thanks guys.
My Honda does not have an RCA out.  It does have an auxiliary connection but it is DIN plug for MP3/CD changer.  There are adaptors that I found on the net Blitzafe and Ice>Link: Plus at LogJam Electronics.
LogJam Electronics are selling Blitzafe universal iPod interface for most cars.  I found one for my car.  :singing:
It looks like they are in the same price as Neo iOn between $150-199.
iPod is bad enough let alone an FM modulator.
Levi
Re: Playing iPod tunes in your car stereo
« Reply #4 on: 31 Jul 2006, 02:20 am »
I found it!  Here is an iPod integrator solution for 2003 Honda Accord: Dice Electronics
I just installed it in my 2003 Honda Accord and it works flawlessly using radio controls.  The stock radio sees the ipod as a CD changer but with only 60GB worth of music. :green:
It also charges the iPod while it is docked.
On top of it all, the sound quality is surprisingly excellent. aa  I highly recommended it.  DIY installation takes only 30mins for first timers.
Here is the breakdown:
Dice Electronics I-Honda-R3 iPod integrator = $159.99 + $10 shipping = $169.99 Total
DIY installation: 30mins or less.
Area below the radio.  Plenty of space as you can see.
iPod installed inside the arm rest w/optional cradle.
mcgsxr
« Reply #5 on: 31 Jul 2006, 02:09 pm »
Nice, I will consider that for my 2003 V6!
Levi
« Reply #6 on: 31 Jul 2006, 02:45 pm »
It is very nice indeed.  Who needs a CD changer?
The integrator kit also has an auxiliary 1/8 phono input.  Can be used with other MP3 devices etc. :o
« Last Edit: 23 Aug 2006, 05:11 pm by Levi »
Levi
« Reply #7 on: 23 Aug 2006, 03:32 pm »
I found this video clip in how to install the ipod adapter for the 7th Generation accord.  It is an excellent DIY from start to finish.
http://www.youtube.com/watch?v=1xm8b4WXCmQ&search=audio%20installs
Hantra
The Dice is the bomb!  I have it in my car, and I love it!!!
Levi
I am curious.  Did you install it youself?
Hantra
I did the install.
It was pretty simple.  I had to take a hacksaw to a piece of my center fold down arm rest, but it's completely stealth now.  And you can't see the saw marks.   :lol:
Levi
Yeah I know it is pretty simple.  Just a little bit of knowledge and tools saved you $150 worth of installation.   :thumb:
