0 Members and 1 Guest are viewing this topic. Read 5230 times.
Curiously, some of the perceived brightness of the tweeter went away when I hook up the subs. I lowpassed the subs at 50 Hz to augment the Bella/SP1's running full and they sound better. I quess psychoacoustics does matter.
Just to tease you a little, there is a difference.........
At the time we developed them I was thinking, "I need to build a speaker at a lower cost and that will move in larger volumes (home theater). One that I don't really care so much (2-channel audio "caring")what it sounds like."Oh well, I've got a million of 'em (ideas for new products). I guess I'll just have to build something else that rocks. Ooops! - too late - already have. How do they sound? Hold tight a few more days. I will say this though: This time I cared what they sound like. In light of the above, use your imagination.
Don't you have your own forum for posting new stuff/ This is my thread, get out.
Wow, don't I feel great after reading that?
An explanation for the leanness could be a complete lack of baffle step compensation in the crossover.
A more likely reason is that room gain is not as strong in woodsyi's room and most folks come to expect the sound you get with it factored in.
The Peerless HDS Exclusive 8" woofer is rated at 89.3 db.
BSC by nature lowers the system sensitivity.
10 Real Traps, 4 GIK panels, 4 8th Nerve corners and acoustic ceiling tiles may be the reason for less then robust room gain.
