This may seem like a weird question, but Kevin (or anybody) do you know of anyone who has used the Extremii (sp?) for bottom octave bass? I know you use them in 3 ways, but I'm thinking in a sub box by themselves. Here's why: I want to build some subs to use with a Tact 2.2x and the recommendation is to cross them fairly high (like as high as 250-400hz). The idea is a 'quick' woofer that won't get muddy.
The recommended Lyngdorf specd woofers are horribly expensive and I don't think I need 4 10" woofers (2 per box).
I'm sure there are plenty of options, but I was thinking the Extremis is reasonably priced, would probably work in a smaller enclosure, and when eq'd by the TacT might have plenty of output with 2 of them (or 4). I would probably use a burly pro amp so I would think headroom shouldn't be an issue with the eq boost. My room is approx 3,100ft2 and I tend to listen fairly loud (90-100db)
Do you think this would be a bad idea? There was a thread back in Sept, but it was a somewhat different application for a small system.
