0 Members and 1 Guest are viewing this topic. Read 6081 times.
Hi Kinnon,What quiescent current are you running your amp at? I've installed a 120mm fan at the back of mine and dropped the voltage of it to 7.5 volts, it is quite audible, but I've set the current to 560ma, it sounds awesome! I'll be purchasing the papst fans whihc are 80mm and only make 12db of noise!!!!I had thought about doing away with the input caps also, and asked David about this, although he did say that it's a nervous subject as you have to check the ofset at the output, and if too high could be problems for the speakers, I havn't tried this, given that I do sometimes change sources.Is your 125 the audiophile version, and what power supplies are you using?I do agree with you about the sound though I have the mos250, and I've not heard anything even come remotely close to what this thing can do.ThanksRaj
Hi,That's the reverse of what I've done, as I've removed the input caps from the buffer amp instead, and it was definatley a worthwhile upgrade. I'd of thought that removing the caps from either the amp or pre would have the same result?Is there anything elese you could share on upgrades etc?ThanksRaj
