0 Members and 1 Guest are viewing this topic. Read 30842 times.
I am assuming that if I use 12 ribbon tweeters in a line array design that the vertical response is not an issue and that the tweeters will see only 1/12 of the distortion that one would see? Am I correct within +/-10%, dave
Any chance that the new Neo8 in your upcoming LS9 will be as impressive as the Neo3?
Will you consider making the LS9 with Neo3's?
Would a conflict of interest exist if you used the Noe3?
