0 Members and 1 Guest are viewing this topic. Read 6488 times.
The change to the volume control is something I can make good use of. I try to avoid being an early adopter of software/firmware changes due to the one step forward two steps back that is so common.Like this potential step back:http://forums.slimdevices.com/showthread.php?s=e138cfb6c69f92282b4660174a0e203c&t=17269As that thread progresses It seems more likely that quality may be impacted.Evidence may only be anecdotal at this point, so wanted to ask here if anyone using the volume control feature has noticed a change to sound quality.Regards,Music Machine
Jakepunk,Could you share the tips how to do it? Thanks.
You need to fake out slimserver 6.2.0 by copying the previous firmware into its directory and telling it that the firmware version is 15 instead of 26. I run FreeBSD with a Squeezebox2. YMMV. 0. assume your slimserver 6.1.1 directory is /usr/local/slimserver1. stop slimserver 6.1.12. rename the slimserver directory to slimserver.6.1.13. install slimserver 6.2.0 to /usr/local/slimserver4. copy slimserver.6.1.1/Firmware/squeezebox2_15.bin to slimserver/Firmware/5. cd slimserver/Firmware/6. c ...
I disabled the digital volume control in the Slimserver player settings page which made it all a moot point. It resulted in a noticeable improvement in sound quality, so I would recommend anyone using a Squeezebox with a preamp or receiver to do the same. No need for two volume controls.
