The Commercial Zone
Audio Shows and Events
Rocky Mountain Audio Fest
Pez
What's playing in Room 7007 at the RMAF
0 Members and 1 Guest are viewing this topic. Read 1620 times.
cryotweaks
Funny name. Serious audio.
27 Sep 2005, 03:23 pm »
TweekGeek RMAF Attendee Specials
http://www.tweekgeek.com/images/RMAF05.jpg" width="735" height="110">
TweekGeek.com will be exhibiting in room #7007 at the upcoming Rocky Mounatin Audio Fest. Below are a few of the products we will be showing, along with some incredible deals on products and services.
SPECIAL PRICING ON ALL PRODUCTS FOR SHOW ATTENDEES ONLY!!!
http://www.tweekgeek.com/images/NuforceReference9Newsletter.jpg" width="200" height="150" hspace="5" vspace="5" align="right">Listen to the
http://www.tweekgeek.com/product.asp?pf_id=nuforceref9
" target="_blank">NuForce Ref 9 Amplifiers - NuForce's Ref 9 is a drastic departure from conventional approaches to switching amplifier design. Most class-D amplifiers use a fixed sawtooth waveform to modulate an audio signal.. Thus most class-D amplifiers have narrow bandwidth due to steep noise filtering at or near 20kHz, and high distortion due to the limited gain of the phase-corrected error amplifier at audio frequencies. NuForce Amplifiers use proprietary technology that eliminates the need for steep filters at 20 kHZ, yielding increased bandwidth, and the design also assures a more phase correct signal.
SPECIAL DEALS ON THE REF 8 AND 9 FOR SHOW ATTENDEES
http://www.tweekgeek.com/images/HarmonicTechcyberlightDig.jpg" width="250" height="166" hspace="5" vspace="5" align="left">Audition the controversial
http://www.tweekgeek.com/product.asp?pf_id=HTechP2A
" target="_blank">Harmonic Technology Cyberlight cables - You've read the reviews, and seen the flame wars on the audio forums. Now Hear them and judge for yourself!Harmonic technology has come up with a unique solution for eliminating EMI/RFI distortion and ground loops in audio cables. CyberLight analog interconnects use patent-pending miniaturized LAM (Light Analog Modules) to convert electrons to photons--laser light--and back again. Therefore Cyberlight cables do not pickup airborne EMI and RFI like standard metal interconnects. Metallurgyand geometry are taken out of the equation too, leaving just pure signal. In addition, CyberLight technology breaks new ground because its photon density modulated light signal actually does break the ground between components -- light can't carry current, meaning no ground loops between Cyberlight connected components! CyberLight Wave Photon Transducer interconnects have zero capacitance, zero inductance, zero skin effect, zero phase shift, and zero signal loss up to 200m!
http://www.tweekgeek.com/images/continuum2.jpg" width="172" height="522" hspace="5" vspace="5" align="right">Experience the
http://www.tweekgeek.com/product.asp?pf_id=Continuum
" target="_blank">SP Technology Continuum Loudspeakers - 2 way MTM floorstander with a unique waveguide tweeter that extends frequency response all the way down to 700Hz. SP Tech loudspeakers offer a unique approach to loudspeaker design. The unique Waveguide enables the 1 Scan Speak dome driver to operate down to 700HZ without compression, additional distortion, or over excursion. This allows for a lower crossover point, enables one driver to produce most of the music, resulting in a much more coherant sound. Speaking of coherance, the Continuum employs a true 4th order, in phase, symmetrical Linkwitz - Riley crossover. Again SP Tech is giving attention towards a more coherent sound with much less phase distortion. Regarding the 8 SEAS aluminum bass driver, SP Tech''s design objectives called for a hybrid approach that has been successfully implemented by the use of an inner chamber that absorbs and diffuses unwanted upper bass and midrange tones. The compact size and bass extension to 30Hz. of a ported design has been achieved with a superior transient response and freedom from the boxy sound often associated with them. SPECIAL, NO MAKE THAT
UNBELIEVABLE
SHOW PRICING FOR ATTENDEES! TO BE ANNOUNCED AT THE SHOW.
http://www.tweekgeek.com/images/Velocitor2.jpg" width="348" height="369" hspace="5" align="left">Walker Audio VelocitorA favorite among reviewers. The Velocitor takes a minimalist approach to line conditioning. Walker Audio incorporates nothing in the power path to alter the power supplied. Utilizing Quantum Resonance Technology running in parallel, the Velocitor does not present electronics with a transformer, inductive or resistive values, capacitance, surge protection, on/off switches or LEDs. All of these, while fixing some problems, present a sonic tradeofff. The Velocitor just delivers unimpeded clean power.The Velocitor isdesigned and built for the best sound and video reproduction possible.
http://www.tweekgeek.com/images/Mk-3F_th.jpg" width="285" height="197" hspace="5" vspace="5" align="left">
NEW!!!
Live demonstrations of a new power conditioner, exclusive to TweekGeek.com! This new conditioner plugs in-between the component and the AC cord to deliver conditioned, and cleansed AC via the shortest path possible without being inside the component itself. Come and hear the difference it makes on our system!Plus - Huge savings on select cables and accessories - Prices have never been this low. Show attendees only!
cryotweaks
27 Sep 2005, 08:22 pm »
I forgot to mention, bring 20 bucks and your favorite CD, and you can make a "Reality Checked" copy of it. I bought one of George's duplicators, and will be bringing it to the show.
Cheers!
The Commercial Zone
Pez
