0 Members and 1 Guest are viewing this topic. Read 5944 times.
I don't see your name on the RMAF exhibitor list this year which is too bad - I'd love to hear them.
If you have no need for the grills then we will not insert the grill support sockets - unless you specifically ask for them. The front panel looks much cleaner without them and it would be a shame to install them if you will not be using the grills. We believe this new "smoother" finish will be more to the liking of most.
Raising the crossover to about 1.1kHz seems to have had a tremendous effect on that tweeter. Although that's only an increase of 150Hz, that little bit seems to have moved that tweeter out of a range that it was a bit unhappy in.
Just a thought. I notice some manufactures these days put magnets behind the front panels to attach the grills which seems like a very neat solution with no deleterious appearance issues. Any reason for not going that route?
But yes, once again you were right. Thanks for the vote!
