AudioCircle Logo - RightAudioCircle Logo - Left
Pages: [1]   Go Down
Author Topic: Off-Ramp Turbo  (Read 4334 times)
0 Members and 1 Guest are viewing this topic.
srclose
Off-Ramp Turbo
« on: 1 May 2005, 09:15 PM »
About 3 weeks ago I began breaking in an Off-Ramp Turbo, and have over 500 hours on it.  I have just finished comparing this USB input to SPDIF input on my system.  Overall, I wouldn't call it a contest.  But here are some thoughts.
Cyrus Chestnut - Revelation - Lord, Lord, Lord
The USB passes more low level information, with background sounds easier to identify; there is some humming in this track.  The piano note attack is cleaner and there is more resonance to the note, a better sense of the sound as it progresses through the note - beginning, middle, and end.  Instruments are more clearly defined and separate.  There is more texture to the bass strings.
Bill Frisell with Dave Holland and Elvin Jones - Outlaws
The soundstage w/USB is much deeper and wider, with much more instrument resonance.  The bass lines are cleaner and the cymbal sounds hang in the air.
Roy Hargrove - Public Enemy - End Of a Love Affair
Off-Ramp provides a rounder trumpet sound, and more texture is evident in the fine brush work.
Eagles - Hell Freezes Over - Get Over It
Noticeably more impact to notes and a more authoratative floor to the music.  The tom-toms in the middle of this track have more air around them and more reverberation.  USB provides a more enveloping sound.
Dallas Wind Symphony - Pomp and Pipes - Vikings From Finland Suite
Much more hall realism, soundstage width/depth, reverberation, more immediacy.  There is greater bass impact and it is easier to discern the note attack on brass instruments.
Ray Charles - Genius Loves Company - Fever
The Off-Ramp version is more involving with more drive from the rhythm section.  Voice inflection is more apparent for both Natalie Cole and Ray Charles.  A more tangible presentation.
Gene Harris - Best of the Concord Years - Captain Bill
Cymbals come in early in this track in the background, and are less fuzzy w/USB and more clearly cymbals rather than just a high frequency sound.  The intonation of notes for the sax is clearer.
There really isn't a quality that wasn't improved going from SPDIF to Off-Ramp.  It's easier and more enjoyable to listen at low levels because the sound remains clear, and easy to listen at high levels because the sound isn't irritating or grating.  The SPDIF is not harsh either and sounds fine until you make a comparison, then it seems you sucked out much of the life of the music.
I was worried when I first hooked up the USB.  The sound was harsh, edgy, and all over you.  It was better at 200 hours and better at 300 hours.  The V-Caps must want a lot of time to settle in.  So far, I prefer to have Foobar set to 16bit with no resampling, and the Transit then set to 16bit.  SPDIF out was clearly better than the Meitner CDD transport that I was using before, but the USB is a hands down winner to digital cable.
The only uncertainty with this comparison, is that I don't know how well the Luminous Audio Allegro cable stacks up.    I was using a Green Hornet digital before, but sold it when I ordered the Off-Ramp.
I don't think you would be disappointed in the performance of the Off-Ramp.  It provides an involving, clear window across different types of music.
Jon L
Off-Ramp Turbo
« Reply #1 on: 1 May 2005, 11:28 PM »
You might want to add an introduction where you specify the exact signal chains being compared along with equipment/amp/speaker/cables used?
For example, what "spdif" are you comparing to Off-ramp turbo?  Is it actual 75 Ohm coax output from your motherboard?  Which motherboard is also important since a lot of Mobo's spdif output is resampled to 48kHz and not bit-perfect.
Also, which output mode in Foobar as you using?  ASIO, Kernel Streaming, Directsound, Waveout?  It wouldn't matter for Transit but is important for Mobo's spdif output.
srclose
Off-Ramp Turbo
« Reply #2 on: 2 May 2005, 12:10 AM »
Quote from: Jon L
Here's some specifics.  I'm using an ASUS K8N E Deluxe MB with Luminous Audio Allegro digital cable.  Interconnects are Luminous Audio Synchestra Reference, and speaker cables are Luminous Audio Synchestra Signature cables.  Preamp is Sonic Euphoria single-ended passive with Dodd Audio 120 W monoblocks.  Speakers are Epiphany Audio 12/12 line source.  Foobar is set to 16 bit fixed output with DirectSound playback and no DSP.  Transit is set to 16 bit.
My room is treated with Eighth Nerve roompack+ with additional Framed Response controllers behind.  Two 2x4 foot Risch fiberglass panels are ~3 inches from the front wall and centered, with two 18" Risch bass traps in the corners behind the speakers.  First reflection points are not treated, and the room is carpeted with 8' ceiling, 10.5' wide, and 18' long.
I'm currently auditioning EA Holophonic interconnects and SAS 10A active preamp.  I hope Nuforce amps are coming soon.
SRC
Jon L
Off-Ramp Turbo
« Reply #3 on: 2 May 2005, 10:49 PM »
"Foobar is set to 16 bit fixed output with DirectSound playback and no DSP"
Well, this wouldn't be a fair comparison b/c then the Mobo's digital output is not bit-perfect as it has to go through the K-mixer, which will resample the digital out to 48kHz.  On the other hand, Transit's driver will be bit-perfect even in direcsound, so it has an unfair advantage.
I'm sure that Offramp will sound better even if ASIO is used in Foobar, but would appreciate a followup report using ASIO plugin for Foobar if possible.
srclose
Off-Ramp Turbo
« Reply #4 on: 3 May 2005, 02:59 AM »
Sorry, should have said using Kernel Streaming for the SPDIF.   :oops:
zybar
  • Registered++
  • 2009 World Series Champions!!!
  • Gallery
  • Systems
Off-Ramp Turbo
« Reply #5 on: 30 May 2005, 12:16 AM »
Was there a comparison to a traditional trasnport?
George
srclose
Off-Ramp Turbo
« Reply #6 on: 30 May 2005, 02:16 AM »
I started out with a Meitner CDD to a Meitner IDAT/M.  The dAck! replaced the IDAT/M and was an improvement.  Awhile later I compared the CDD to PC SPDIF and the PC was better than the CDD.  It was recently that I purchased the Off-Ramp, and it was clearly better than the SPDIF.  Each of these has been step-wise and I sold equipment as it was replaced, so I don't have a transport to compare with the Off-Ramp.  I have listened to much of the same music though, and I am hearing more information from a cut off of the XRCD Waltz for Debbie or Pomp and Pipes, for instance, than I have with any of the other combinations.  The EA modded dAck! w/V-Caps combined with Off-Ramp is very clear, clean, and smooth.
Pages: [1]   Go Up
« previous next »
Page created in 0.135 seconds with 45 queries.
