0 Members and 1 Guest are viewing this topic. Read 7296 times.
I've tried a bunch of coupling caps in my tube amp, tube headphone amp and preamp. IME the Jupiter Copper Foil 600v is the best sounding cap out there. Much better than the teflon caps, PIO, or other film types. Dueland caps are slightly different sounding (a bit warmer), but not better sounding. And of course Dueland is like 3x the cost of the Jupiters.I like tube rectification - gives another option for tailoring the sound to my preference.
Yeah? I've never tried Dueland because the price is so prohibitive, but I've used the original Jupiter caps and they were very nice.Maybe the Copper foil is the way to go?As for tube rectification, this circuit will only pull about 80mA or so total, so we have basically all the tube rectifiers available. I usually use the 5Y3 in this type of scenario because of easy availability and low NOS prices. What is your preference for rectifier tubes?
Yep, copper Jupiters are a big step up over the originals. Like I said, Dueland level (at least in my system).Rectifier tubes - only have much experience with the 5ar4 and the 6X5. If the 5Y3 sounds good and has low cost NOS options then that's better than the 5ar4, which is ridiculously expensive for NOS.
II) For rectification, do you prefer a SS rectifier with large electrolytic caps for filtering or a tube rectifier and film caps?III) If you answered tube rectifier for the above, what kinds of power supply caps are your favorite?
SS diodes for DC rectification made a lot of noise, as HPs are more detailed than speakers SS diodes are a drawnback, I dont know the sound of caps to say what is my favorite
That's true, but you do have the option to use much larger capacitors for filtering with SS, so that's a plus I'm gonna go with tube rectification and probably canned oil caps from ASC, though.
Looks good. Do you think half wave tubes as 6D22 are a drawback?Since is need two of them.
This looks the Khozmo? I also use it, the 100k log.
Congratulations Wolf.Poland is big source of quality hi-fi manufacturers.Not need use copper amp table, its expensive and heat dissipations is near the same as aluminium, I could use 3 or 5mm alu, just a idea.Real wood for base is good looking and absorb transformers vibrations, there is 3 flavors: soft woods, hard woods and both in the same frame.
