My 4B-SST² 29dB/23dB switch. now to 23dB since new speakers
0 Members and 1 Guest are viewing this topic. Read 930 times.
Elizabeth
The Bryston amplifiers have a switch on the back to alter he gain to either 23dB, or 29dB. Matching the gain to the RCA, or XLR.
When I had Magnepan 3.6 (for 8 years) I found the 23dB gain position (using XLR in) on my 4B-SST² to be a bit subdued compared to the 29dB gain, which had more definition and 'pop'. So even though I was using XLR in, I used the 29dB switch position.
Well, with my new Magnepan 20.7 to same amp in the 29dB position is a bit edgy, and so I tried the 23dB and now just right. Smooth and clear.
Always pays to fiddle with stuff.
john1970
Re: My 4B-SST² 29dB/23dB switch. now to 23dB since new speakers
« Reply #1 on: 18 Mar 2018, 11:53 pm »
Interesting observation.  I have been using Bryston amps of different varieties over the past decade and with my new pair of 7B3 I decided to try the 23 dB setting instead of the 29 dB setting (while using balanced interconnects).  I find the new setting also to be more a bit less edgy and smoother on the treble.  Speakers are Magico S5 MK2s.
John
TJ-Sully
« Reply #2 on: 20 Mar 2018, 11:01 pm »
Nice speakers John! are you able to share a photo?  :thumb:
