CES/T.H.E. Show
0 Members and 1 Guest are viewing this topic. Read 3580 times.
CIAudio
CES/T.H.E. Show
« on: 2 Jan 2005, 03:16 am »
For those of you attending CES in Las Vegas, we'll be displaying with ModWright and Revelation Audio Labs at the St. Tropez, Room 2005.
Stop by to hear the new D-100 Class D monoblocks and also our new
VHP-1 headphone amplifier
Hope to see you there!
CIAudio
CES/T.H.E. Show
« Reply #1 on: 20 Jan 2005, 04:42 am »
Here are a few links to reports/photos from CES/T.H.E. Show in Las Vegas
6moons http://www.6moons.com/industryfeatures/ces05/ces_6.html
Audiogon http://live.audiogon.com/cgi-bin/ces.pl?channelislandsa&&ManuView&ST&st41&&&&&THE05
At the Alexis Park, our new D-100 Class D Monoblocks were used to power the new Line Arrays from Nearfield Acoustics/Pipedreams
Our VPC-1 Passive Preamp and VMB-1 Monoblocks were on display in the Thorough Bass Inc. room
http://live.audiogon.com/cgi-bin/ces.pl?&ST_2008&RoomView&ST&st61&&&&&THE05
Music Direct also ran demos of our new VHP-1 Headphone Amplifier
CES/T.H.E. Show
« Reply #2 on: 20 Jan 2005, 12:18 pm »
Dusty,
What are, "... all the shortcomings of conventional Class D designs" that the 100/180-watt into 8/4 ohms D-100 monos [$1,599/pr] are said to overcome?
Are we to understand that Paul Candy of 6moons will be reviewing the chip monoblocks?
What pre-amps do you recommend for the digital or chip monoblocks?
TIA
CIAudio
CES/T.H.E. Show
« Reply #3 on: 20 Jan 2005, 03:20 pm »
There are two main problems with conventional Class D amplifiers.
The first being they have load dependant frequency response...for example, a B&O ICE module is designed for a 6 ohm load. When driving a 4 ohm load, the high frequencies are rolled off, when driving an 8 ohm load, the high frequencies rise.
The second problem is high voltage DC at the speaker outputs. If an amplifier uses a single supply of 100vDC, it will have +50v at both speaker terminals. This is a shock hazard and cannot be approved by UL.
You'll notice many manufactuers use Speakon or similar connectors instead of binding posts to get around this.
The D-100's frequency response is independant of the load, and uses a split rail power supply with no DC voltage at the speaker outputs.
CIAudio
CES/T.H.E. Show
« Reply #4 on: 20 Jan 2005, 03:31 pm »
The VMB-1's are scheduled to be reviewed by Paul Candy at 6moons and Greg Weaver at Positive Feedback.
We also have reviewers asking for D-100's when we have enough to go around.
VMB-1's work best with a passive because of their hi gain(32db), but we have several customers using them with active preamps also.
D-100's are available in 26db gain for active preamps or 32 db gain for passives.
CES/T.H.E. Show
« Reply #5 on: 20 Jan 2005, 08:55 pm »
Thanks for the quick response Dusty.
You should update your website.  It doesn't mention 26 and 32 dB gain options.  I was always leary of passive preamps, especially with the low output of phone pre-amps and some DACs.  But with the extra 6 dB of gain many of the passive worries should go away.
I'm sure many will be looking forward to the reviews.
mr_bill
CES/T.H.E. Show
« Reply #6 on: 20 Jan 2005, 11:29 pm »
Which modules do you use for the new digital monoblocks?  B&O Ice or Tripath or something else?
Bill
CIAudio
CES/T.H.E. Show
« Reply #7 on: 21 Jan 2005, 12:50 am »
something else :wink:
CIAudio
CES/T.H.E. Show
« Reply #8 on: 26 Jan 2005, 05:15 am »
John Kotches
CES/T.H.E. Show
« Reply #9 on: 27 Jan 2005, 12:55 pm »
Hypex UCD modules, but who's talking ;)
